Guys not sure if i've put this is correct section. I once read a thread here (which i now cant find) on electric reverse set ups on a bec. The
starter motor etc was mounted in the tunnel with the ring gear etc mounted to the engine at the prop adptor side.
I fancy doing one of these now as i need this to enter my car into the road going class at hillclimbs, and i also am considering putting the car
though its iva,
Any pics information etc would be great, ie starter motor used etc,
O its on my 1999 R1 engine as well if that makes any difference
Can't help on the tech but incase you missed it theres an electric reverse for sale buried in this thread from eznfrank. Might save you a few quid on a new one!
Check user 40 inches, he's done an excellent thread on it. With all the suppliers of the parts etc.
Search for posts by "40inches"...
Or take a look on this: http://www.locostbuilders.co.uk/viewthread.php?tid=154985
If you want the full kit I bought the starter motor, cog for diff flange and mounting brackets from MK. Phil had some in stock when I last went. They are custom made for the job and are not cheap but I have found it very useful not to mention controllable. It is a pig to fit but well worth the agro once complete.
