Rad fan switch
ed1max - 20/7/11 at 03:19 PM
Hi all,
I've got a 16600X flow in my westie,can anyone tell me the correct temp range should be on the fan switch.
Regards and thanks for any advice.
Eddie
shindha - 20/7/11 at 03:51 PM
Mine runs between 80 - 90 degrees but I have to have the fan on in traffic especially if the weathers warm - i have a manual switch usually switch it on from the word go in hot weather.
britishtrident - 20/7/11 at 03:58 PM
Somewhere around 91 to 97c, no point in having it lower than the thermostat start to open temp, on at 95 off at 93 should be fine.
It should be fitted in the cooling circuit on the rad side of the thermostat never before the thermostat, ideally in the rad itself failing that in the top hose.
