Hi guys,
I can't find any reference to it in the omex hardware manual but, is there any reason why the omex ecu can't be sited right next to the coil
pack or will the coil pack cause interference with it? Is there a minimum separation requirement?
Cheers, John.
its a good question, i would guess and its only a guess, that modern supressed coil leads won't interfere, but you could always ring omex for a definate answer.
I put mine under the scuttle out of the way of any water getting at it. I find the front of the scuttel has water marks on it after being caught out in the rain.
I have also put mine under scuttle but with the mapping terminal exposed for ease of mapping
Thanks guys,
Under the scuttle it goes then, I really don't know why I didn't think of that before.
Cheers, John.
