I am using Savage switches (brushed ali type) on the car but not sure how to wire them.
It has a little diagram in the box but I can't work out what goes where really.
There's a block with the switch (is this a relay??) there's six connectors on the block and then two on the actual switch that push through
the block. The diagram mentions N/O, N/C, LED Cathode +, LED Cathode - and common. Just wondered what they all stand for!
ta,
Rich.
N/O normally open
N/C " " closed
leds are polarity conscious and the common will most likely be power in.
hi Rich...
where did you get your switches...
I was going to get them but was convinced I would find somewhere cheaper than demon thieves....
Get them here.
http://www.speeding.co.uk/
then 'miscellaneous' then 'switch'
[Edited on 9/8/04 by wicket]
hi Wicket...
thanks for that...they are a bit dearer...free delivery though.
Got mine from MAC1 motorsports at £17.99 each.
thanks for the link though, has a guide for fitting!!
Rich.
I like the switches, there are some on ebay at the moment....
link
I ordered the starter switch control panel last week,i'll let you know the quality when it arrives
[Edited on 9/8/04 by bob]
SAVAGE starter switch control panel arrived today from iconstyling through an ebay puchase.
The item is very well made with good quality switches,looks and feels better than some of the stuff i've seen at the shows and nearly half the
price.
As sold in monkeyhunters link above
