hi where is the best place to mount my fuse/rely box for an mk??????
cheers steve
Buxton
Somewhere easy to get to! I put mine upside down under the scuttle to get it out of the way.
Suffice to say changing a fuse leaves me with little dignity, not that I had much to start with.
Stu
Mine are next to the battery in the engine bay.
[img]
Battery Bulkhead
[/img]
Somewhere easily accessible.
Mine are on the bulkhead with all the relays and alot of wiring in the space between the bulkhead and dash.
Close to the battery works well but high up on scuttle is a good place to start there is no reason not to have more than one fuse box or location. just put it where it is easy to get at and check. fuses never blow in daylight or when its not raining........in my experience.......
