Hi all,
Ive been trying for a couple of weeks to upload my base map to my 600. I had a serial port connector and no joy. Omex told me to the Aten serial
connector which I did still no joy. I have power to the ECU and have tried to laptops 1 on windows 7 one on XP. It just keeps saying ecu offline. Omex
have asked me to send the ecu back for testing but I suspect theyre gonna tell me the ECU is fine. Has anyone else come across this??
PS. Com ports checked and verified
no but omex are fantastic when ive had any issues
does the software (i presume there's some sort of omex software you need to use?) have any settings on it?
i've got mega jolt on mine, and the software has a setting of what com port to use, and it needs to match the com port setting for the serial
adapter in the device manager
plug the serial adapter in, restart the computer to be on the safe side, open device manager, and expand "ports (com&lpt)" it should say
what com port its set to. for example, as i have no adapter plugged in, i've got bluetooth on com5, maybe your adapter might say com4 (think
thats what mine went to
then go into the omex software, look for options, and see if you can change the com port it operates on
give me, er, a while, and i'll find my adapter in the garage, plug it in and see if i can get some kind of screen shots of how to sort it on my
megajolt software, might help a bit with the omex one, maybe?
edit: i know you say com ports checked and verified (i saw that after i posted lol) , but i'm sure there something not quite right there.
[Edited on 30/11/11 by blakep82]
I tried that mate but tend to agree there's something not communicating. I'm sure when Omex test the ecu they're gonna tell me it's fine
what adapter is it? is it one of thise usb/serial adapters?
i didn't quite understand part of the first post, "Omex told me to the Aten serial connector which I did still no joy"
is it an adapter that they recommended? if so, they must know its compatable with the omex,
i think you're right, they'll test it and say its fine, i reckon there's some sort of setting on your computer thats not quite right
I have Map 3000 loaded on my XP desktop and it works fine. I use an ancient laptop with win 98se to communicate with the ECU because it has a genuine
serial port so links with no issues. I have never had any connection problems. Connection issues are usually due to USB to serial adapters not working
correctly.
In the software you can check under ECU and set the correct baud rate (set to auto for automatic detection) and com port. Ignition on and click
connect and it should work if the adapter is compatible.
One solution is to buy/find an ancient laptop with a serial port.
I had similar issues crop up with connecting my DTA ECU USB-to-serial using a Vista laptop. A possible route to solution (at least what I needed to
do!):
1) Make sure you've got the latest adaptor drivers compatible with your O/S. This may take a bit of Googling and research to find out what chip
your adaptor uses etc. Should be a lot easier stating from a known, working brand...
2) Check what COM ports are available for the mapping software to use, and the adaptor driver can use, and make sure they are the same!
3) I found that mine would only recognise the ECU having done the above, and then only through one of the 3 USB ports on the laptop... so try another
USB port is the other tip.
As I said, I'm DTA, not Omex, but one might assume that many USB to serial issues will be common.
Good luck!
