hi all
just a bit of advice i have just got my zx9r engine to upgrade from my pinto the zx engine as been in a mk before and only has a short amount of loom
basicly engine wiring. my car has been running fine with pinto but ive read threads where people use the complete bike loom and some join it onto a
car loom i was wondering which would be easier to get a bike loom or try to connect it on to my pinto loom
all info would be great
The pinto looms should be in two parts, engine loom and another loom for everything else. Remove the engine loom and replace with the bike one, im assuming the bike loom already has the lighting circuits etc removed. Then just wire up the ignition side of the bike loom and it should be bobs your uncle.
I also did the same upgrade. I stripped out the pinto engine loom leaving in the fan and lighting circuit and just added the zx9 loom.
Brad.
