my fuel gauge reads 1/4 when my tank is empty is this an easy fix does it just involve bending the float arm not really sure whats the best fix
thanks in advance
Bit of a daft question given the price of fuel, But what does it read when full, with the durite type sender it can be a simple case of just bending
the arm, a bit more info might be a help like make of clock and sender
tony
hi its a smiths clock and a basic escort tank with the original sender it reads off the clock when full
Are you using a voltage stabiliser? if not then it is most likely due to the voltage to gauge and sender being to high, you would be best to find a
sender to match the gauge along with a matching voltage stabiliser.
Paul
