what coilpack is this plug made for ?, as it dont fit mine..... and if i get the correct pack to suit the plug, will my ht leads still fit ?
[img]
[/img]
Why not do it the other way and get the
correct plug to fit the pack.
its a premade omex loom.
supposedly made to fit the coilpack i have...
may be easier/quicker to swap coil packs than try to return a loom i have started to fit
If its a Omex loom thats intended to be used on standard Zetec then they should be replacing it as the Oval connector is standard zetec Dispac.
duratec.... will that make a difference?
Theres plenty of zetecs with that plug in the scrapyard so I would just chop it off and fit the correct plug with a bit of solder and heat shrink
assuming everything else is correct.
If you get stuck for the plug im sure that I must have one here somewhere.
Paul
got one on its way..... a new one
apparently the plug is the new duratec one....
