Hi all
I need a TPS for my gsxr ITBs which will be running on an Omex 600 ecu eventually.
there are a couple of TPS's on ebay at the moment but im unsure if they will fit and if they are the correct ones for my ITB's
the ITB's are k1 - k3.
The TPS ive been looking at is :
Suzuki GSXR750 K8 L0 08 11 Throttle Servo TPS #13624 | eBay
what concerns me is that after looking at numerous images of these TB's they seem to have 2 or 3 Tps but the one that fits directly to the
TB's has a black plug whereas the one in the link has a white plug.....is it likely this isnt actually a TPS?
Hope someone can help.
Many thanks
Patrick
GSXR have 2 tps, one is on the primary throttles (the one controlled by the cable), the other is on the secondary throttles (which are controlled by a
servo, this servo also manages the additional air during warmup).
I think the one you have there is the one from the secondary throttle plates.
I think you want one that looks like item number 251019359332
Thanks Matt
I had a feeling this myt be the case.
Any ideas for another place to source the correct tps from?.....I suppose ringing around some bike breakers is my best bet.
Thanks for the help
Patrick
Be careful when sourcing.
My experience is that the TPS is the weak link in an otherwise long-lived system. They do fail due to the wear on the potentiometer track, also the
internal spring weakens. First signs are usually a jittery noise on idle, follwed by the ECU getting really upset when the fault later develops.
Thanks...is there anywhere I can buy them new then? Maybe more expensive but at least Id know its going to work OK.
Patrick
