crank pickup issue
beaver34 - 8/4/12 at 06:30 AM
just turned my engine over and im getting no crank signal
its omex 600 using stock ford crank sensor that worked fine before, the setting in the ecu are a base map from omex
ive changed the mx timing either way but to no avail, how do i check the sensor is wired correctly?
thanks
dave r - 8/4/12 at 07:26 AM
someone on here the other week had the same issues... turned out the supplied loom was wrong
click me
[Edited on 8/4/12 by dave r]
beaver34 - 8/4/12 at 09:20 AM
thank, ill check the loom but im 99% its right as i have run it last year
how do i check for continuity of the wiring?
beaver34 - 8/4/12 at 11:27 AM
fixed, was connector on the end was not a genuine ford one and did not clip on correctly, now just need a fuel pump then should fire up
