Piggyback spades or two wires into one crimp?
JekRankin - 8/6/12 at 05:39 PM
As per the title really, which is the better method for joining two wires at the same terminal - a piggy back spade, or two wires crimped into a regular spade? Soldering isn't an option for me, since I'm rubbish at it and I've just spent £50 quid on a crimp tool :-)
Many thanks,
Jek
daniel mason - 8/6/12 at 05:41 PM
can you solder the 2 wires together then crimp in one crimp?
Macbeast - 8/6/12 at 05:50 PM
Apart from the fact that he said he was rubbish at soldering, it's a bad idea to crimp over solder as it creeps over time.
I would piggyback as it gives you the option of disconnecting one but not the other should you wish to.
avagolen - 8/6/12 at 05:50 PM
Please do not solder then crimp. Not a good idea.
If the crimp is big enough for all the copper bits and the insulation will fit cleanly into the
strain relief, crimp both wires into a single crimp.
If not, put the most important, higher load into the piggyback crimp and the lesser load onto that crimp that plugs onto the piggyback.
HTH
Len.
JekRankin - 8/6/12 at 06:18 PM
Thanks for the replies all,
I've tried crimping two wires into one terminal and the joint feels pretty strong. I've added a bit of adhesive heat shrink to make sure.
I think I'll use the odd piggyback spade to allow me to keep the bike, lighting and digidash looms as separate as possible.
Jek
AntonUK - 8/6/12 at 06:33 PM
I either crimp, solder and heatshrink both into the same one or do one and solder a pigtail to the wire for the 2nd (lower power) item.
