I'm after a 3hp motor and Machine Mart list two...
One is 2 pole and the other is 4 pole. What I need to know is the difference in this? I know 4 pole goes at 1500rpm and the 2 pole at 3000rpm, but,
what exactly does this mean? Is one more reliable, better duty cycle??
Want to build a saw and need the blade to go round about 4500rpm.. so a 4" pulley on the motor, 2.5" on the arbor...
Any thoughts electrical boffins??
Ta,
Neither have a commutator so should be reliable.
speed=(120 x freq)/no. of poles where freq is 50Hz in the UK.
So the 4 pole will have double the torque of the 2 pole assuming they have the same power rating.
As you state 4 pole 1500rpm 1400 rpm in real terms and 2 pole 3000rpm (2800 rpm).
If you use pulleys to drive your blade at 4500rpm both will be the same.
The main difference will be the pulley sizes.
On important thing, is the smaller the (blade) shaft pulley to deeper cut you can make.
My father has made 2 diy bench saws and I fairly sure both were 2 pole.
Just remember these machines must be used with care.
Seen a 6mmx6mm piece come off the blade and put half way through a fire door.
Seen a 6mmx6mm piece come off the blade and put half way through a fire door.![]()
If you just want a basic set up I would go for a four pole on a DOL (direct on line starter) for the extra torque. There are a lot of knots and nails
in that type of wood.
If you can afford it use an inverter as your motor controller that gives you the option to tune the motor and can provide motor braking.
Don't forget to wire in some type of volt free relay or E stop.
A word of caution if you are wanting to use this pallet type wood in a log burner, lots of manufacturers don't recommend its use, don't know
why though.
Originally posted by I predict a Riot
A word of caution if you are wanting to use this pallet type wood in a log burner, lots of manufacturers don't recommend its use, don't know why though.
Pallet wood is full of nails which will jam in your grate and are a real pain to remove.
Duncan
Dont worry about the nails chaps, I've been burning this stuff for 2 years now and as you say there are more nails than ash.. however, she doesn't complain about lifting them out as the heat is free!
