Looking at fitting some 5 3/4 round headlight unit to my seven but do not have sidelights built in what separate sidelight units are everyone
using.
Seen these but want to know what else is available.
2 Button 12v Hyper Bright White LED lights Sidelight | eBay
Thanks Matty
i quite like those
Is your car already on the road? as if it isint i doubt they would be SVA compliant/ E marked
Yes car is already on the road just changing from 7 inch lights to 5 3/4 but messed up and got units without a sidelight.
A bit more expensive but I quite like the look of these for sidlights.
Pair LED projector lens button bolts white leds, CNC black case no plate light | eBay
strictly speaking your car should comply with the requirements of the SVA/IVA at all times and altering after the test to a standard that does not comply is illegal.....now i know the chance of being caught is limited....... how ever i do know that some police forces are getting wise to this practice and are doing checks on some kits they stop. the most common fine is for illegally placed headlights.
