hi there
do i need a rear fog light on my kit car ? to pass an mot ?
many thanks
striker-4age
Yes you need a rear fog light
Its also pretty silly not to have one...
[Edited on 20/10/12 by Ben_Copeland]
Definitely yes, as Ben said
As most kit cars are very low, it'd doubly important to be seen in the fog.
Also a high level brake light on the roll bar is a good idea.
good luck
René
Fog lights are the one thing i would ban tomorrow, they serve almost no useful purpose and represent a bigger hazard than the safety they provide.
The highway code says they should ONLY be used when the visibility in FOG (not mist or rain) is less than 100 meters i.e. about 1 or 2 times a year. most drivers seem to think they must go on at the first sign of a misty day and stay on for a week at least. by and large the are as useful as a chocolate fire guard.
However the powers that be seem to think they are a good idea so we are stuck with them, i never use mine.... even in thicker mist.![]()
YES - you do need a fog light. It also needs to be the correct made-for-purpose lens as that lens sends out a parrallel beam as opposed to a wide
spread all the other lights do. It is important to position it correctly - the lens has to be at 90 degrees to the road so the pencil beam goes
towards following (ground) traffic - not air traffic! It also needs to be separated by so many cms from eg. the brake light.
Check the details in the manual carefully (It was one fail point in my IVA - I had used a light with the wrong lens).
____________________________________________________________________________________________________________________
Quoting snowy:
_____________________________________________________________________________________________________________________
Whilst I agree wholeheartedly with your points about the various muppet uses of foglights, they are 100% essential when in THICK fog - if you say they
serve no useful purpose, you must never have driven in serious fog - I mean when you can't see the kerbs, the road markings, etc.
Living in East Anglia (fog capitol of the world) I wouldn't be without rear fog lights.
There are various sensible solutions to the fog light problem - in an old Toyota of mine, the fogs were switched on with a push button. As soon as
the ignition was turned off, the fogs reset to off. Later on I had a Ford Focus - that had a switch tied into the headlights - you couldn't put
the fogs on until the headlights were turned on, and once you turned the ordinary lights off the fogs went off as well (same for my daughter's VW
Golf). My current Yaris has the fogs on a column switch that is also mechanically linked to the headlight switch - turn off the headlights and the
fogs get pushed to off.
So any manufacturer that allows the driver to leave the fogs on needs a clip round its commercial ear...
[Edited on 20/10/12 by David Jenkins]
going to try my luck at the mot as it has never had one.................and i am never going to be out in the fog
only time will tell
Originally posted by striker-4age
going to try my luck at the mot as it has never had one.................and i am never going to be out in the fog![]()
only time will tell![]()
If the car is later than 1st April 1980 then rear fog light (s) are a legal requirement.
If 2 are fitted they must be a matched pair.
The location of them in relation to the other rear lights is important.
Hope this helps.
so if the reg is from the donor car ??? pre 1980 ?
No kitcar manufactured date. Nothing to do with donor.
Retests aren't always free usually they are only free if the necessary repairs are done by the garage and thecar doesn't leave the premises.
Whilst I agree wholeheartedly with your points about the various muppet uses of foglights, they are 100% essential when in THICK fog - if you say they serve no useful purpose, you must never have driven in serious fog - I mean when you can't see the kerbs, the road markings, etc.
So if the fog is so bad you can't see and have to stop. What stops people hitting you if you have no foglights? Even parked at the side of the
road etc. you'll still be a serious hazard.
I do agree people that use them when they shouldn't should be shot, but they are useful for identifying slower moving vehicles from a distance.
You shouldn't be getting close enough to the back of people in thick fog to be dazzled. I drive all over the country in all weather and in
different vehicles and I wouldn't be without fog lights even if I only use them couple times a year.
So if the fog is so bad you can't see and have to stop. What stops people hitting you if you have no foglights? Even parked at the side of the road etc. you'll still be a serious hazard.
I do agree people that use them when they shouldn't should be shot, but they are useful for identifying slower moving vehicles from a distance. You shouldn't be getting close enough to the back of people in thick fog to be dazzled. I drive all over the country in all weather and in different vehicles and I wouldn't be without fog lights even if I only use them couple times a year.
