Hi guys,
Just wondering if anyone uses the Torque Pro Android app for
diagnostics? It looks pretty interesting (and cheap) to me but I have an Omex 600 ECU with a serial RS-232 connector rather than the OBD interface
required for the app, could anyone think of a way to get these things talking to each other?
I've seen ELM237 (copy) bluetooth adapters on eBay along with RS-232 > OBD adapters, but I imagine connecting all this stuff up wouldn't
produce the desired results because the ECU would need to be outputting via the OBDII protocol?
Russ.
Yeah that combination isn't going to work.
I think someone on here did some work on a similar app for non-OBD2 ECU's (perhaps megasquirt?) have a search on here??
I've found this:
www.msdroid.com
...which is what I assume you were referring to. Unfortunately I haven't managed to find anyone developing something similar for Omex ECU's
My only hope in the short-term is to find something relatively ECU agnostic, or give up trying to connect my mobile to the ECU and play with apps
using GPS and the accelerometer (though clearly not as interesting).
Anyone out there have any Android app recommendations for the driving enthusiast?
Russ.
You need to speak to omex.
Im sure their software is free and you only need a USB to serial converter which cost pennies.
