Hi Guys,
I'm going to use Smiths Telemetrix gauges with my zx12-r
Speedometer
Tachometer
Fuel level
Oil pressure
Oil Temp
Water temp
Does anyone know...
1, Will the bike fuel sender work with the smiths fuel gauge?
2, Will the speed sender on the bike work with the smiths speedo?
I've bought an oil pressure sender and an oil temp sender and I assume the Smiths tachometer will be ok with the output from the ECU.
Any thoughts appreciated.
Stu
Hello,
all i know is that the Zx12 engine oil pressure is quite low (23 psi).
that can be difficult to have a good reading with standarts oil pressure gauges
Gerardo
