steering wheel wiring
beaver34 - 22/12/12 at 09:48 AM
im wanting to install two buttons on my wheel
the wheel is removable so i want to have the wiring on a connector to some flex cable mounted under the dash
anyone done it before, and i want a proper connector that will last, any recommendations of which type and where to purchase from?
thanks
MakeEverything - 22/12/12 at 12:18 PM
get a 4 pin milspec plug and coiled flex (like telephone wire but with a larger conductor). like
this
and COILED CURLEY PVC EXTENDIBLE 3 CORE MAINS FLEX 13A NEW
ETA: ive used those plugs and had them imported from hong kong without any issues so far.
[Edited on 22-12-12, by MakeEverything]
beaver34 - 31/12/12 at 11:15 PM
those connectors do they need some applicator so i can install the wires? and are they quarter turn fit or screw together?
thanks
Neadles - 1/1/13 at 12:43 PM
Those connectors just require you to solder the wires into them, no special needs, RS have plenty like it that I have used if you want more colours or sizes.
