i have recently rewired my MK Indy using a vicky green loom,since the rewire my batt light is constantly on & the alt does not seem to be
charging,i have disconnected the main batt lead at the alt & tested the voltage across the alt terminal & ground & nothing??,i presumed
the alternator was fried so bought a replacement but the same problem still exists its a denso alternator from a suzuki swift on a 2.0l zetec
blacktop
http://www.startermotor-alternator-store.co.uk/suzuki-swift--50-amp-alternator--10-sf--13i-a2663-4335-p.asp
above is the alternator i have with 3 connections on the back lamp/ignition,dumy ??
any ideas what i have done wrong or whats happening?
have you confirmed that the 12v excitation is getting from the ignition switch to the alternator?
you could also connect a supply directly to the ignition terminal just to check out the alternator is charging.
The connections have to look like this. VG loom won't have a built in ignition live and you must add one.
[img]
Denso SwiftConnections
[/img]
Thanks guys I will check the wiring again today as per that dirgram & see how mine compares.
