I'm looking to replace the earth wiring on my tintop, so I don't get the obscene alternator whine that is currently blocking any attempts to listen to music. Can anyone suggest a source of reasonably thick cable? Maplin stuff seems really overpriced and I'd rather not do Ebay if possible.
Alternator whine is not likely to be earth related, not wholly anyway. what you need is some capacitors from the alternator live ( often called suppressors) your aerial may also need moving or may even need earthing its self.
phone chargers can be extremely noisy electrically and if your radio and the cig lighter socket share the same supply from the battery it can make the problem worse. a crappy battery will also not help.
