Have fitted some H,I,D bulbs with ballast packs. Wow what a difference, looks like the lights you get on mercs now. Big thanks to the person who told me just to change the bulbs. Kev.
Be prepared for all the people that are about to go on about you need head light washers and auto levelling lights etc etc now you have HIDs.
Where did you get the kits btw??
Fleebay 30 pounds for the lot
make sure you swap them round for MoT time!
No need to swap them round at mot time for aftermarket fitted hid kits, only time they will fail is if the beam pattern is incorrect
can you get hid kits for standard 7 stle lights as mine are rubbish at night!
New Mot rules came in last year:
http://www.theaa.com/motoring_advice/car-servicing-repair/mot-changes-2012.html
The second part of the new mot rules came in middle march 2013 which includes HID amongst who items
You can get HID conversions for pretty much any car. Its not the type of light that really counts, just the type of bulb. I would assume you have H4 bulbs and they are most definately available.
The 2006 DfT report that mandated headlamp washers and self-levelling was eventually going to be introduced in 2012 - but then wasn't :-)
looking at the size I guess they won't fit into a standard 7 style headlight
I would assume the bulbs themselves arent much different in size, its just the rear part thats quite large. Do the pictured ones have seperate
ballast's or are they integrated in to the back? If so maybe some will have the ballasts remote which may aid install in to a tight space.
a club member is selling these on our site with great success - you can see the remote ballast units in the second to last pic:
12v 35W HID Xenon Conversion kit bi-xenon H4-3 (Hi/Lo) 6000K
This conversion kit allows you to have Xenon Lights on both dipped and main beam!
The H4 kits are supplied with bulbs that electronically switch in order to change the bulbs from low to high beams. The bulbs are powered directly
from the battery via a wiring loom, this kit can be used on all cars or bikes with h4 bulbs.
Easy to install, no wire cutting, no stress:
. Just plug in each connection - 30minutes no cable cutting/joining!!!
. All cables plug directly into your cars existing cables with only one earth connection needed (cable is already wired with a ring connector)
. Included wiring harness has all the necessary connectors
Main Features:
* The input ranges: from 9V~16V, which means they can be installed on both cars and bikes without any further modification
* Waterproof and dustproof. Resistant to heat and vibration tested
* 3 times light output - 300% brighter than the average equivalent 60 watt halogen lighting
* 10 times longer life - 3000 hours of life
Package Contents:
. 12v 35W HID Kit bi-xenon H4 (Hi/Lo) 6000K
. 2x hid xenon bulbs
. 2x hid ballast 12v 35W
. 2x ballast holders
. The H4 (Hi/Lo) bulbs are supplied with the special relay wiring harness required for Hi and Low beam. . All fixing included: Bolts, screws and
wires
. Installation manual - Instruction in English for wiring and installation
[Edited on 10/4/13 by scimjim]
Oh so the rear part is just the dipped/main motor/solenoid.
I suppose the other option would be to install dipped H4 HID bulbs which are slimmer in the main headlight then add spot lights for main beams
elsewhere.
HID light conversions are not legal. they also now fail mot‘s Unless your headlights are self leveling AND you have headlight washers fitted.
also HID bulbs give a poor pattern if not used on the right headlamps.
