I have just bought a sw3001 switch but I have not got the wiring info.
Can you help.....
Savage switch wiring
Any help?
Ben,
Thanks for the quick reply and help.
That's great.
How's you?
Originally posted by jossey
Ben,
That's great.
How's you?
Ye that's the one.
I'm using a key ignition as the switch.
Ah ok, I didnt want that as it seemed bit silly turning the key and then pushing button.
Aircraft style flip switch and button, much cooler
Ye I agree now I've seen your pic. I've just ordered a aircraft switch like yours. Great thinking :-)
Wiring is not yet done and its a fire blade engine so I guess I need a relay.....
Aircraft style flip switch and button, much cooler![]()
That does look pretty cool. How does it work with IVA? Does there need to be a key somewhere to stop people pinching the car?!?!
Just make sure the starting relay is only active while the alternator light is on.
Wasn't fitted for IVA, I have a battery isolation key under bonnet and plan to fit a removable steering wheel.
