My kit died on me last week. I was supposed to be hooning it away from a Pistonheads pub meet, but instead, it spat its dummy, and died just as the
traffic lights were about to go green (in front of a gathered crowd - idiot I know). I had a quick look, and found it had two blown fuses - one for
the ECU, and one for the ignition circuit. I changed them, and it started fine, ran again, but died 10s later. This time there were no blown fuses, it
was turning over just fine, but no fuel pump whirr.... It was getting dark, so it meant a trip home courtesy of the RAC (and they took forever!).
So I have taken the scuttle off to inspect the wiring, but I can't find anything dubious (well - no more so than usual!). I have checked the fuel
pump relay (4-pin Omron part), and with the ignition on, i get a voltage at 3 of the 4 terminals, suggesting to me that the relay is not working
(there is no audible click when switched on).
So is my relay broken? Would a failing relay have caused my blown fuses, or should I suspect to find some damaged wire somewhere?
Any help much appreciated - it is too sunny to have the car in bits!
Silly question time.. but have you got an impact cut off switch on the fuel pump?
Originally posted by twybrow
I have checked the fuel pump relay (4-pin Omron part), and with the ignition on, i get a voltage at 3 of the 4 terminals,
That sounds like the relay is working as intended. Two of the connection will be the relay coil, of which one side will be ground and the other side at 12v when energised. The other two will be the contacts, and if the relay is closed and connected properly to the 12v supply you would expect 12v on both of these, so three of the four terminals should have 12v, and one should be close to ground potential (assuming low side switch on the ECU).
Obviously you can prove this by measuring the voltage across the pump during the priming cycle, or when cranking.
If the pump is no longer priming, and fuses have blown it sounds more like the pump itself, or the wiring to the pump has burnt out.
Injection ecus pretty much universally provide a ground to the fuel pump relay coil to operate the pump.
Try disconnecting the wire to the ecu and with the ignition on, earth the relay coil directly. If the pump runs, or you at least get 12V on both of
the relay switch terminals, your relay is ok and the fault is elsewhere.
Cheers R
[Edited on 18/7/13 by rachaeljf]
Try disconnecting the wire to the ecu and with the ignition on, earth the relay coil directly. If the pump runs, or you at least get 12V on both of the relay switch terminals, your relay is ok and the fault is elsewhere.
Cheers R
The top connection is an odd one. I can only think the ecu monitors the fuel pump relay. It's common for the fuel pump relay to feed both the
pump and the injectors, and lambda sensor too if you have one.
The second connection is odd too, it must be the permanent live feed, via the ecu for some reason.
The third connection is how your ecu controls the fuel pump, by grounding the relay coil.
I took the relay off, and tested it. It clicked nicely, and I had continuity on the other two terminals when energised.... I then put it back onto the
car, and I get 12V at three of the terminals, and a low voltage (0.03-0.06V) showing on the 4th terminal which is what should go on to power the fuel
pump etc. I can't hear a click either... Grrrrr!
If I had a short on this wire - how can I test for this? How can I find it, or is it a case of just pulling all of the loom apart until I (maybe) find
a chaffed wire?
If you have 12V on the relay coil-ecu terminal when trying to start the engine, the ecu isn't grounding the relay coil. This could be because the
ecu isn't getting the required signals from its sensors to run the engine, or the coil grounding transistor in the ecu has blown. If at any stage
12V has inadvertently been applied directly to the ecu's grounding transistor while the ecu has been operating, it will blow.
You can try grounding the coil-ecu wire, which won't harm the ecu's grounding transistor but will allow the pump and injectors to operate,
and see if you can get the engine to run.
To test for a short on the wire that powers the pump etc., unplug your injectors and pump and simply measure the wire's resistance to earth with
a meter. You will get a lowish reading because you may still have a couple of items connected, e.g. lambda heater but if it is less than around 0.5
ohm you have a short.
If you have 12V on the relay coil-ecu terminal when trying to start the engine, the ecu isn't grounding the relay coil. This could be because the ecu isn't getting the required signals from its sensors to run the engine, or the coil grounding transistor in the ecu has blown. If at any stage 12V has inadvertently been applied directly to the ecu's grounding transistor while the ecu has been operating, it will blow.
You can try grounding the coil-ecu wire, which won't harm the ecu's grounding transistor but will allow the pump and injectors to operate, and see if you can get the engine to run.
To test for a short on the wire that powers the pump etc., unplug your injectors and pump and simply measure the wire's resistance to earth with a meter. You will get a lowish reading because you may still have a couple of items connected, e.g. lambda heater but if it is less than around 0.5 ohm you have a short.
Sorry if this has already been mentioned as I'm trying to read this on my phone but:
The ECU won't give the fuel pump relay a ground until it sees the engine turning over so check to see if there is a tacho signal. If the tacho
isn't reading anything as you're trying to start the engine, it ccould be a good place to start loolking!
The ECU won't give the fuel pump relay a ground until it sees the engine turning over so check to see if there is a tacho signal. If the tacho isn't reading anything as you're trying to start the engine, it ccould be a good place to start loolking!
Are you saying it isn't giving the priming pulse you usually get?
If it isn't priming on first switch on, in rough order of likelihood:
1) the earth wire and/or the supply wire to the pump has come adrift
2) the pump itself has died
3) the ecu isn't getting an ignition 12V supply,
4) the ecu earth wire(s) have come adrift, or
5) the pump relay grounding transistor in the ecu has died (as Mike says the ecu electronics rarely fail unless abused)
Hope that helps!
Hope that helps!
I have checked for shorts and cant find any, and the pins in the ecu have been checked for continuity to the relay. There is current going into the
ecu from the relay coil, and coming out of the ecu to go back to the relay switch, but it seems the ecu is not grounding the coil of the relay, as
there is no click.
What would cause an ecu to do that?
Are there certain essential sensors giving readings when you first switch on the ignition
got a paper clip handy ? switch ignition on ....
short across the relay to make it live all the time , and check for the pump running , if it doesnt its the wiring/pump .
