HI MY SAXO TURNS OVER BUT DOSENT START THE IMMOBILISER LIGHT IS FLASHING ON DASHBOARD IVE HAD A DIAGNOSTICS TEST DONE AND IT SAYS ITS AN ECU FAULT. WHAT DO I DO NOW?
Buy another ecu?
Stop shouting, keep calm and fit another ECU to see what happens..
Welcome BTW.
Do i need to change the ignition barrel aswell?
Has the key got a transponder in it? If so you need the ECU and key or they need programming together.
Ok thanks i will get an ecu and key and see how i get on ill let you know.
Have you tried disconnecting the battery and leaving it for a while ? Have a look on the bba reman site.
yeah ive tried battery. the imobaliser light is flashing on dash and the diagnostics test said there is a fault with ecu.
There's a place near Nottingham that repairs ecu's, have used them for Renault kit search on Google there's a few out there.
There's a few places that will fix them and you can also get replacement ECU's that are 'code free'.
No doubt you have checked for dodgy connections on the ECU ? They are a bit exposed on the Saxo.
I will have a look for an ecu that isnt coded will this solve my problem do ya think?
If you have a confirmed internal issue with the ECU a 'code free' replacement would sort any transponder issues.
You'll need to weigh up the cost comparison of doing it this way against the standard ECU etc,
Another thing to consider is i'm not sure how the insurance companies view the 'code free' ECU's ?
Have you had a price to just repair your existing ECU ? there are a few companies about that can fix them and turn the repair around pretty quickly.
With the ECU on a saxo you can just buy an unlocked on from someone when you hook it up to your car and if the ECU was at fault it will recode
its-self when plugged in with an imobiliser connected, if its an imobiliser issue i would be tempted to remove the imobiliser before you try another
ECU to the make sure, also make sure you get the right ECU their were a few different versions for each engine varient if you need/want to remove the
imobiliser box you can just unplug it from behind the dash lots of walkthroughs on saxo/106 forums
Where are you based i know a couple of guys near middlesbrough who could fix these things with their eye shut and know the pin outs on the plugs by
heart
Sheep
