wiring a single flasher relay for Indicators & Hazards
snippy - 27/8/13 at 06:21 PM
I am using a 3 pin Flasher Relay (pins 31, 49, 49a). Its marked as 4x21w + (2x5w) so should be ok to be used for Indicators & Hazards. I`ve got the indicators working fine. I want to wire in a new hazard switch because the car I am rebuilding has never had hazards. I`ve got a simple 3pin illuminated rocker switch to act as my hazard switch. Do I simply run a 12v+ switched feed wire from my rocker switch to pin 49 for the hazard circuit? I`m using an old Escort mk1 loom by the way.
theduck - 27/8/13 at 08:18 PM
This superb diagram any help?
loggyboy - 28/8/13 at 08:43 AM
Above is simplest solution if using standard switches. However it can cause a clash with hazards and indicators activated at the same time, not a regulation issue, but would annoy me!
A relay linked to the hazard switch to deactivate the supply to the indocators would do the trick.
The other option is to use an OE hazard switch, which its own mechanism will deactivate the indcator supply when the hazards are on.
snippy - 4/9/13 at 04:51 PM
Still struggling with this, not sure if I have understood above diagram correctly. Maybe I need an idiots guide? Anyone?
YQUSTA - 4/9/13 at 07:13 PM
What part don't you understand?
blakep82 - 4/9/13 at 07:38 PM
I dont like using diodes for this sort of thing.
What about this? Sorry about the blank page on this, but you should be able to see it ok. Small lights are the warning lamps
Of course I forgot the hazard warning lamp... hmmm cant remember how that bit worked now. I suppose you could put it on one output from the 2 pole switch, would still need a diode though
[Edited on 4/9/13 by blakep82]
snippy - 4/9/13 at 08:12 PM
Maybe it's easier if I just wire in a seperate relay for the hazards?
YQUSTA - 4/9/13 at 08:24 PM
If you post a diagram of what you have at the moment it can be sorted very easy.
loggyboy - 4/9/13 at 10:07 PM
What happens when you turn both hazards and an indocator on tho?
ReMan - 6/9/13 at 09:23 PM
It still works. As noted this would still need diodes (or a different switch) to drive a dash warning light
snowy2 - 8/9/13 at 08:40 AM
does this work for you?
term 15 = ignition live
term 30 = battery live
The flasher receives power from one of 2 fuses, depending on whether or not the Hazard switch is operated. The same flasher is used for both Turn Indicator and Hazard functions.
Internal circuitry in the flasher keeps a small "sense" voltage on Terminal #49a all the time. When the Indicator stalk is pulled to Left or Right, the Indicator bulbs on that side are connected to Terminal #49a and load the flasher circuit so that it knows to begin flashing. Immediately, the internal relay contact closes from (+) to #49a and the bulbs light. The flasher electronic circuit then turns the relay off and on to provide the flashing cycle.
The 4-terminal flasher has a built-in load sensing relay which drives the dash indicator. The dash indicator flashes in time with the Turn Indicator bulbs.
The dash speedo indicator bulb used with the 3-terminal flasher relay is connected from the (+) supply to #49a and it flashes opposite to the Turn Indicator bulbs. For example, when the Turn Indicator bulbs are lit, there is +12V present at #49a. That means that both sides of the dash bulb have +12V on them and no current can flow thru the bulb.
The only difference in circuit operation for Hazards is that the flasher receives power from the second fuse, which is live whether or not the Ignition is switched On or not. The Hazard switch has another set of contacts (not shown here) which connects both Left and Right sets of bulbs to the flasher.
this may also help...
and a link to the source site...
http://www.nls.net/mp/volks/htm/signals.htm
[Edited on 8/9/13 by snowy2]
