Hi,
Has anyone fitted one and can tell me how to do it?
Wots a throttle pot?
Mark
Didnt you get any instructions with it?
My Emerald/Jenvey one just fits to the end of the throttle spindle. Spindle turns pot resistance goes up. It will need to be calibrated with the ECU, simply takes closed reading and full open reading and allows ECU to take throttle open angle into consideration for ignition timing if running carbs.
