Hi can any one help?
I'm wiring in window wipers and washer into a B517x BG11k665 ford stalk.
The washer works ok as the neutral comes from 53c and when the button is pressed it goes onto 54.
The problem is that 53 and 53a high /low speed wiper are
Commoned up with 54,so only will turn on when washers are pressed.
Has any one got a drawing or can help.
try reversing the first two wires (53c 54)
I see what you mean but 53c is already made off and going somewhere else
I am sure diagrams are available on here if you search enough, painful as the search engine is....it will eventually turn something up.
I had a problem with lights pre SVA and found this helped.
http://www.locostbuilders.co.uk/viewthread.php?tid=24253
