Are you allowed to use one dash warning light for your handbrake and your brake fluid level?
yup
Cheers Conrod. Much appreciated
Do you also have to have a warning light for your side lights/dip beam?
i didn't i used the bright light module which only has main beem..
[Edited on 1/11/04 by macspeedy]
you only need a main beam warning light,pref blue
Side and dip illuminate your panel lights so you know something's on. That's good enough.
You will need to fit a test option to the fluid level light if you don't use it as the handbrake light. I think they need you to be able to prove that there is a means to check the bulb is working whenever you drive the car.
