This is probably a nonsense but I’m still trying to find a genuinely LoCost solution to getting some good looking analogue instruments and could do
with understanding how modern donor instruments work.
The general consensus seems to be that you can’t use donor instruments without the associated OEM engine management but presumably inside the speedo
or tacho housing is actually a stepper motor or, on older cars, a moving coil meter. Although I’m no expert on either I assume the reason newer
gauges have to be used with the original ECU is that the stepper motor drive is actually in the ECU.
If this is the case then couldn’t this function be done by a separate stepper motor drive getting a pulsed input from either the ignition system (in
the case of the tacho) or from a suitable sensor in the case of a speedo?
I suspect my lack of understanding means it seems simpler than it actually is but there do seem to be motor driver IC’s available reasonably so would
it be possible to use these to create an interface between the ignition system / speedo sensor and the donor instruments?
I know I’d need someone to actually design the circuit but if it were possible it would potentially open up a supply of almost new instruments at low
cost.
John.
Originally posted by John P
The general consensus seems to be that you can’t use donor instruments without the associated OEM engine management but presumably inside the speedo or tacho housing is actually a stepper motor or, on older cars, a moving coil meter. Although I’m no expert on either I assume the reason newer gauges have to be used with the original ECU is that the stepper motor drive is actually in the ECU.
If this is the case then couldn’t this function be done by a separate stepper motor drive getting a pulsed input from either the ignition system (in the case of the tacho) or from a suitable sensor in the case of a speedo?
I suspect my lack of understanding means it seems simpler than it actually is but there do seem to be motor driver IC’s available reasonably so would it be possible to use these to create an interface between the ignition system / speedo sensor and the donor instruments?
I know I’d need someone to actually design the circuit but if it were possible it would potentially open up a supply of almost new instruments at low cost.
John.
In my eyes its not the drive that is the issue its the calibration.
The older the dials the more chance you have of solving it.
I have two suggestions for this.
I have managed to splice together some Peugeot/Citroen clocks to a Ford engine and factory ECU. Somewhat of a surprise that it worked - esp the
electronic speedo. Obviously the key is serious detective work on the wiring.
The benefit of this is that modern production car clocks are very cheap on eBay and that the latest ones are also very compact.
I can provide more info if people are interested.
The other suggestion is the use of a Bluetooth adaptor to the diagnostic can bus socket, if your ECU provides that, and use a smart mobile phone
diagnostic app. I use one called Torque. It works extremely well providing calibrated measurements of engine temperature for example. Combined with a
high quality mounting bracket it can provide a real alternative to physical instruments for very low cost. I suspect it ma not be fully legal as there
can be no proper odometer, however I guess you cold attach a hidden one in the engine bay or something for that.
Perhaps the ultimate version of this would be to use a suitably sized cheapo android tablet built into the dash specifically for the purpose (although
note that some of the really cheap ones don't have Bluetooth or GPS, which are both needed)
