Hello guys I've still not got a spark on the blade engine, I've not got any power down the pulse side or the tps side got earths but that's it the ecu has some live and some earths. There is a grey wire which is connected to a clutch diode which goes to the side stand and earthed I've got power to the coils and that's it, there is no pink wire to the ecu. Any help would be good
Have you got the coil packs wired up correctly? Do you want me to take a picture of mine and e-mail it to you?
Also are you sure that there isn't a pink wire? It's an immobiliser and needs to be hooked to love with a correct valid resistor.
Any help would be good. 12 wires to my ecu
Assuming you are not using the Honda keyswitch, then most likely you don't have a 100 ohm drop resistor in your VC line to the ICM.
The wire to the ICM should be pink.
wiring
I haven't got a pink wire on my ecu
Could this be the problem the coil wire are bridged with a +supply that's why they have power should there be the resistor in this line?
As promised I've uploaded a couple of photo and also left you a couple of U2U's
If all else fails give Andy Bates a call at AB Performance he'll give you loads of advice
Iain
Have you got it sorted yet?
Not yet
have you got any volts to the coils?
Yes there is power there
So you have power to the coils, but the ecu isn't grounding them to give you your spark. Is the loom the same as it was in the bike or is it
cut/extended etc?
All the ignition cutouts i've seen are clutch switch if you are starting in gear, sidestand switch and tip over sensor. You say that you have
grounded one of the switches, what I would do would be to see if the switch opens or closes the circuit in the run position and then if it closes the
circuit in the run position (more than likely) then connect the two wires running to the switch. You might not be correct in thinking that the wire
has to be earthed, it might have to connect to the other wire with it.
Dave
Hay guys had a quick play tonight went back over everything put new terminals on everywhere and hay presto I have a spark and a engine that fired up
cheers for everyone's advice. Cheers
