My problem is - hazards work fine with ignition off. When I switch ignition on the hazards are on. If I remove the hazard switch I still have the
problem, but when I disconnect wiring from sierra indictors stalk hazards work fine with/without ignition on. I'm using a tiger supplied loom and
digidash2 lite.
Anyone come across this problem?
[Edited on 30/4/14 by neilp1]
Sounds like your feeding switched live back into the hazard circuit somewhere. I used a diode to fix my problem but I knew where the leak was.
I think you will need a diode but it's just finding where to put it
I had a similar but not exactly same problem, indicator stalk was the culprit.
All fixed now. I had wired the telltale wiring straight to digidash. Once I added the telltale warning lights and a feed off them it worked fine!
