Hella 55mm Light Connectors
Furyous - 13/6/14 at 12:44 AM
I'm using some Hella 55mm style rear lights but I'm having trouble finding connectors for them. Two of the lights are actual Hella products, and the connection is a junior timer but with the two pins in a T shape instead of parallel ( - - ). I can only find junior timers with parallel connections.
The other lights have this connection:
I could just use spade crimps but I'd quite like to do it properly.
Any pointers on where to find the right connections?
omega 24 v6 - 13/6/14 at 06:10 AM
Not much help but I've worked with a lot of hella products and never seen a connector like that. Are the lights new?? I suspect if not then the connector would have come with them when they were new.
Got a link to the actual lamps?
Furyous - 13/6/14 at 07:46 AM
Only two of the lights are actual Hella brand. The ones in the photo are the same style but a different brand. They were all bought second hand with no connectors.
They're the same style Rob Collingridge is using:
http://www.robcollingridge.com/kitcar/design/lighting/
ken555 - 13/6/14 at 08:03 AM
Looks like a Dean connector as used in radio control batteries
http://www.rcmodelcentre.co.uk/deans-connectors/cat_350.html
blakep82 - 13/6/14 at 08:04 AM
I'd contact hella asking them. I did for a set of lights I bought and they sent me a set of connectors free of charge
loggyboy - 13/6/14 at 08:24 AM
How big are the spades?
Could just be the basic 2 pin T spade connectors:
Motorcycle Electrical Multi-Connector 6.3mm 2 way pin T
