first up, transistors
i know theres a few ways to do this (oil pressure and battery charge related, but i think this might be a neater solution, if not a little bit more
complicated)
I've got one of the CBS start buttons with an LED in it, I want the LED to come on when the engine's not running, and go off when it starts.
I've got a rev gauge which consisted of 5 LEDs controlled by megajolt, just set to different RPMs, i want the first one to come on when the
engine is at idle. the lowest value it can be set to is 500rpm, and i'd guess it should idle around 800 or so? so fine, when the engines running,
the first light is on, lets call that led, led 1, and the starter button led 2.
I'm after a circuit that when led 1 is on, led 2 is off
and when 1 is off, 2 is on.
the user outputs can go to a current up to 500ma, so should be well within that
I've just got no idea how to spec transistors, or make the circuit up.
the second question about IVA is toggle switches. always said they can't really be used on the dashboard (except in the exampt area behind the
steering wheel,
however: "Interior design features and fittings in the “specified zone” which are contactable with a 165mm sphere in a forward direction must
have a radius of curvature of 2.5mm or greater, except where a projection from a panel is less than 3.2mm where the edges must be at least
blunted."
so if i had a toggle switch with one of those rubber covers, making the end of it 5mm wide, then it should be ok?
I'm thinking i really should have switches for ignition and fuel pump, so i can put one or the other on individually. there will be times when i
want the ignition on without the fuel pump pumping away. also, do i need a fuel pump relay? as far as i can tell the current draw is only about
1.5A
the other option is rocker switches, but i don't like the look of most of them, especially those ones you used to get in minis.
It is called a bistable:
http://www.electronics-tutorials.ws/waveforms/bistable.html
If the toggle switches are behind the steering wheel they are ok I believe.
Just Wire the LED in the start button asan alternator waring lamp. That way when the engine ( alternator ) is running the light will go out.
And yes toggle switch covers will be OK for IVA if greater than 3mm radius.
RD
[Edited on 3/7/14 by rallyingden]
Alternative to the alternator is to wire the start button to earth to the oil pressure switch, so it comes on when no pressure. Alternator idea
sounds better though, now why didn't I think of that?
I've used switches for fuel pump and ignition, both running via relays. The fuel pump switch was after reading some of the fire horror stories
on here. The start button is in series with both so it only comes on when both switches are on, though tbh I now think it's probably as well to
have it always live. It's useful while testing things to be able to turn each thing on individually.
But mostly it makes you feel like a fighter pilot when turning everything on
Originally posted by The Black Flash
Alternative to the alternator is to wire the start button to earth to the oil pressure switch, so it comes on when no pressure. Alternator idea sounds better though, now why didn't I think of that?
Thanks for all the info there Mike
It'll take me a while to get my head around it though
If I get the current draw for the leds (both '12v'
could you build one in a little box for me?
In fact, its basically a not gate isnt it?
Just to clarify a point, on the oil pressure/alternator thing, I wanted this effect to be a little more clear cut and instant.
If the engine stalls, the oil pressure light stays off a while until the pressure drops. Charge lights can flicker at idle, but I want it a definite
on and off as soon as the engine starts, and on as soon as the engine stalls, if I stall it...
[Edited on 3/7/14 by blakep82]
Originally posted by blakep82
Thanks for all the info there Mike![]()
If I get the current draw for the leds (both '12v'could you build one in a little box for me?
its an aluminium plate, with 5 leds glued in, all separate, and 10 seperate wires out the back
this, in fact
worth pointing out too, that megajolt can power these user outputs in normal (off until over the rev or load limit) or inverted, so on until over the
limit) so it can power either led, leaving the inverter to power the 'bigger' load if needed
each was to be wired to the user outputs on megajolt (4 of them) the 5th is to go to the shift light
first LED is blue and is to be set to come on at 500 rpm (i'd guess the engine should idle around 800rpm) and basically just indicated the engine
is running, although that should be pretty obvious without a light telling you!
when the engines is not running, i'd like the start button to light, and as soon as its started, i'd like it to go off (as the blue rev led
comes on).
yes the oil pressure light or alternator light would do it, and probably be a whole lot easier, but not as slick
if the start button can 'pulse' even better
lol (semi serious there!)
RD![]()
