Not quite a Locost but... I've just been helping a mate out with an electrical fault on his Mk1 MR2. We have keyed it down to a connector which
is shown below. Does anyone know where we can get a connector like this? Or failing that, even what they are actually called? Looks like a generic
part you see on loads of cars so assuming it's not a Toyota only thing
What does it plug into?
If its just another plug then for the sake of a sigle wire I would cut and crimp both sides of the plug (but only the single wire) bypassing that
plug.
If it goes into a unit then you will almost defineatly have to get it from a donor MR2. The lug and latch locations are all different on OEM cars and
plugs. It may look simple and generic, it wont be!
Cheers, it goes into some kind of board/hub along with a load of other similar connectors and a ribbon connector. So guessing despite it's generic look we won't be getting one from Halfords or CBS or anyone.. Bugger
Go on the Yazaki Webby, find the connector and order some samples, make sure you order all the parts including crimps. Ask for 10 of each part and they send them out pronto in a jiffy bag.
That sounds like a decent plan! I'll send that info over to my mate. Cheers!
Originally posted by Skirrow
Not quite a Locost but... I've just been helping a mate out with an electrical fault on his Mk1 MR2. We have keyed it down to a connector which is shown below. Does anyone know where we can get a connector like this? Or failing that, even what they are actually called? Looks like a generic part you see on loads of cars so assuming it's not a Toyota only thing
By-pass the affected pin with 150mm of cable and a couple of Scotchlok tap conectors.
Cheers for the info fellas. Don't think I can bypass it as it goes into a board of some sort. Not sure if there are circuits inside the board or if each cable in connects up to several others but don't think it's as simple as connecting one with to another sadly
Cheers coyoteboy, I have proper crimping gear and bullet connectors so if we need to make any connections that's not a problem. They have the
transparent plastic sleeves which I believe are waterproof but it's all inside the car anyway thankfully so shouldn't get wet.
The board side is a little brown but doesn't look significantly burnt. I'll ask him to have a look at the wiring diagram and work out what
it is grounding and report back shortly. CHeers!
What was the second of the 2 worries by the way?
I've managed to locate it on the wiring diagrams and it looks like it's the main earth for various systems. It's pin 6 as shown on the
following pic - http://screencast.com/t/aOWcYsPT
Is there any logical way of testing each component to work out which is causing it to overheat? I'm not great with electrics but if I attach a
multimeter between the pin on the board and the pin on the connector will the resistance shoot up when the dodgy circuit is in use? ie. can I watch
the meter and switch lights on and so on until I find the dodgy thing?
Any help much appreciated. He has a 1 week deadline now before he can no longer use his missus' car!
And, possibly a stupid question, but why didn't the relevant fuse blow instead of this junction overheating?
