I know this is a subject that has been covered several times on here and the pros and cons of doing it but I have decided to add an override switch to
my loom while I am doing the wiring.
Refering to the post by Snowy2 here I have used his drawing as a guide.
The question I have is really as to the wiring of the override switch and lamp, I have done it this way to reduce the amount of wiring required and
would just like it checked by the wiring experts on here that what I have done will work correctly.
Fan-override
the circuit looks ok, but the lower diagram shows relay contacts not the coil on 85/86
Yep, your right.
I have adjusted it now, is this correct?
Looks indentical to me.
Changed the relay contacts on 85/86 to coil...
Can't remember the correct relay wiring numbers but I have wired mine so the lamp comes on when the fan comes on. It comes on both when when the switch is thrown and the thermostatic temp swicth turns the fan on. The theory being if the fan comes on whilst driving you can see that it has come on alerting you to a potential problem.
fan
Works so the light comes on with the fan
Sorry only have paint handy
[Edited on 19-1-15 by ken555]
Originally posted by ken555
fan
I have a 2 colour LED when its energised by the temp switch its green
But if I override it it shows Red
[Edited on 19/1/15 by Trollyjack]
Hi i use a switch on the dash that had double pole switch
Here is a photo of my wiring that shows the fan wiring
Err ok, really confused now with your diagram. Having looked up dual colour LEDs it shows them if current flows one way the LED lights one colour and
another colour if it flows the other way, however your diagram using the double pole switch suggests that the current flows through it both ways
whenever the switch is made. I could understand if it was a single pole switch as the current would flow one way when the switch was made and another
way when the Thermo switch made...???
Sorry but just trying to understand this, does it need the double pole switch?
EDIT: Ok having looked at it again it looks like the LED you are using has three legs not two like the ones I was looking at, is that right?
[Edited on 19/1/15 by tims31]
The light has 3 legs one is - the other two are + one lights up orange the other lights it up green when both are high the light is yellow
Ok, So ive had a look at the diagram I used before, articles on three leg LEDs and refering to trollyjacks image.
I may be completely wrong but would the diagram shown below work to have the LED light one colour for the Fan running through the normal thermo switch
and another running through the override switch??
Radfan3led
Having looked again it would be permenently on , time for a rethink..
Cannot see that working why have you 2 earths on the led
Also I did not use a relay to control the fan
I used a fan swith of a polo and they dont use a relay.
Like this maybe - but ensure you have a shared cathode/negative bi colour LED
(ignore the warning lamp notation, I forgot to move it back!)
Fan Warning Bi LED
[Edited on 20-1-15 by loggyboy]
Not sure if that would work you are using the led earth also to pull down the relay.
Assuming it was a 12v LED, should be fine.
Of it was a standard 2-3v LED then it would need a seperate circuit with extra relays or similar.
Fan Warning Bi LED
Fan Warning Bi LED
Ok I have tried again, just as a way of reducing another run of cable from the dash to the front of the car and assuming I use a 12v LED do you think this may work instead?
In my article with the diagram it tells you how to wire it with the minimum wire.
the bulb will light whenever the fan is "on"
I have had another look at trying to use a three leg/colour LED that will show a different colour depending on which switch is used, either the Thermo
switch or the override switch.
Does this look like it would work this way?
I know it is using another wire but I can run that no problems at the moment.
You have 2 unnecessary earth's, one to right of relay that will short past the led. And another to left of overide switch. Take those out and you have the same circuit I posted!
Thanks Loggyboy, when you say a 12v LED, are there dedicated 12v LEDs or are they just normal LEDs with resistors to reduce the working voltage? Would the one atthe bottom of here be ok and would that work to pull down the relay?
I added the earths to the switches as I was concerend that if the LED was to fail then there would be no earth to operate the relay from either switch and the fan would not operate...
Look its really simple....ANY SUITABLE AND CLOSE TO HAND 12V SUPPLY ........Under the dash goes to a switch the switched side goes to BOTH the LED
(and then from the led to earth) and to the relay contacts (85)
from the fuse box a wire goes to the thermostatic switch ( AND Pin 30 on the relay) and then the other contact to pin 85 on the relay. Pin 86 to
earth........pin 87 to the fan (s)
You only need one wire from the dash!
Yes, thanks Snowy2. I did understand how to have it wired for just the single colour LED and for both the Thermo switch and override but was just trying to see if it was possible (or should I say easy enough) to do with a dual colour LED. It seems that I would be over complicating things and so will just go ahead with the single colour LED, just thought I would ask the question that was all...
