I am at the point of wanting to get the right ignition leads to go with my crank fired ignition.
The ideal solution would have straight connectors at the coil pack end (gen 2 coil pack which always seem to have right angles leads on to them).
The spark plusgs would be better with right angled connections (pinto).
The coil pack end particularly looks to be an odd requirement, does anyone know if all the above exist and if there are proper names for the ends I
need?
[Edited on 8/2/15 by simonrh]
There may be some info here which may be of use
