I have just fitted some led rear lights and the indicators don't flash.Hazards work fine.Was sent a relay with them from bolt on bits but the relay in my wiring loom from aries motorsport has the indicator and headlight relay combined.Called bolt on bits and was told that I needed some load resisters which have now come,how exactly do you wire these in.there is a live and earth wire do you just connect them to the earth and live going to the indicators????????????
Fit an electronic flasher relay that does not require a load (2 x 21W) to work!
P.S. Resisors
[Edited on 8/2/15 by theprisioner]
P.S. Resisors
