Want to fit a shift light into the Megajolt, has anyone any advise or recommendations on how this can be done?
There are several channels you can program based on RPM
so you can use a simple LED for a 1 light shift
Or use a relay to switch a bigger light
You can configure several outputs for revs to switch a Green yellow red sequential
The info is available on Autosportslabs forum
I fitted one on mine some years ago, there is an output from the megajolt unit specifically for a shiftlight, if you look on the Autosportslabs
website and look at the user manual pdf it shows which pin it is etc. Thereare also a couple of user defined outputs that you can use if you want to
fit the type of light that uses different colour LED's for different rev levels. Once youve fitted the light you need to go into the megajolt
controller software to set the revs you want the light to come on at and then flash it to the megajolt memory.
if you cant find the downloads let me know and i'll find the link to them
Ian
Brill thanks lads........
