Looking to build a new megasquirt loom for the v8 rather than butcher the rover one that still works..
Where can I get injector and temp sensor plugs from cheap. In the vehicle wiring products catalogue they have junior timer and junior power timer
housings. Which ones which??
And, is there a source for plugs with a length of wire attached?
Living in hope...
Easy way is buy an injector loom intended for LPG conversion
http://www.tinleytech.co.uk/acatalog/Online_Catalogue_Looms_and_Plugs_71.html
Steve, I've got a bag full of reclaimed plugs from Jag XJ6 injection manifolds I've 'acquired', how soon do you need them? cos I'm off to Holland tonight for the Assen WSB round, if you can wait I'll send you some, how many do you need?
Need about 10...
I've found a seller on the bay who is quite cheap, cheaper than vwp...
And, I'm just thinking out loud, next item I need is some followers for my new cam so I can rebuild the engine!
Hi Coozer
Did you get the plugs,and were they any good.It's difficult to know if the supplier is good or not.
I'm after superseal plugs and boots and can't decide who to choose any help would be appreciated
Allan 14
Barnard Castle
2.o Zetec Rush building
