Hello all
Can anyone help I have 3 questions on the digidash?
1. In simple terms what buttons do I press when I arrive back at the same circuit as previously visited. So i can get all my sector splits and
don't have to reset everything.
2. What does 'timer armed' mean?
3. I don't have a disc but when i plug a download lead from the DD2 into the USB on my laptop nothing happens. I want to set everything on the
laptop and look through the data
Ive tried ETB and always found them to be very helpful but any advice on here would be very helpful.
thanks in advance
[Edited on 8/7/15 by 750mc]
No sure on your first two questions but on the third have you installed the usb/serial converter driver to you laptop, if so on the etb software you
need to select the correct COM output on the drop down menu.
If you need the driver PM me your email and ill send it across i got it from ETB
Adam
[Edited on 9/7/15 by Adam]
