Hi
Does anyone know where I can get the cancelling bit that fits between the steering wheel and the indicator stalk for a sierra steering column?
I'm got a rally designs steering wheel on.
Its about the FINAL thing to sort out before the IVA!!
Ben
Self canceling isnt required for IVA BTW.
problem solved!!
Thanks!
Mine went through IVA without, but I sorted it after IVA because I kept forgetting to cancel the indicators.
If anyone does have the bits for a Ford column I'd be interested. I can't hear the relay and bright sunlight washes out the lights on the dash.
Self cancelling isnt required for IVA but the spaced bit is required on Sierra columns to pre-load/centralise the top column bearing, along with the spring spacer piece. Without it you'll have play in the column.
Originally posted by 40inches
Mine went through IVA without, but I sorted it after IVA because I kept forgetting to cancel the indicators.![]()
I have fitted a buzzer and it is very annoying!
+1
Tried it once, didn't like it. Too annoying so I ripped it back out...
I just cut the end of a rivet and welded it to the steering column and filed it to the same shape as the fgord bit. Works great.
