I was looking for a Cartek GT Isolation Kit but have been told they give a lot of trouble anyone have or use similar?
Whats wrong with a good old fashioned not to mention cheap as chips Autolec master switch?
This is what 99% of use use on kit cars etc,
UNIVERSAL CAR BOAT VAN BUS TRUCK BATTERY ISOLATOR DISCONNECT CUT OFF KILL SWITCH
At the money they sell for id stick with a traditional key!
I know what you mean doesn't make much sense pay more and get trouble
unless your building a dedicated track car i dont see the point in fitting an isolation switch..
Range hyperstores sell them very cheaply
Strange though seems Range are a handy place to buy bubble packed car electrical odds and ends.
The expensive solid state ones apparently are spark proof.I'm not sure though I would trust a semiconductor to isolate huge amounts of current
other than instantaneously.
Easy to implement engine kill facility on cheap isolating switches such as the Autolec with a bleed resistor grounding alternator output.
I bought the one with brass connections & pin as opposed to "looks like copper but is actually steel."
I payed a little more but then I'm like that.
Why?
So that when I park those mothers that allow their little darlings to play with the switches don't flatten the battery.
Paul G
