I have fitted a quick release boss to my steering column, as a result I have had to move the I gnition switch to the dash, (which needed doing anyway due it being faulty and worn), now I need to relocate my indicator switch to a toggle type to the right hand side of the dash, can anyone recommend a good quality switch which will do the job, obviously it will need to be three way with a neutral position when in the centre position.....
http://www.carbuildersolutions.com/uk/dash-board-illuminated-indicator-switch-onoffon
No ideaa of cost but durite do custom switches.
http://www.durite.co.uk/s/c/switches-and-indicators/modular-rocker-switches-and-warning-lights
