Really hard to start until it's connected to another car!
lordbenny - 23/2/16 at 03:10 PM
Zetec Westfield is really hard to start from cold. It's got a brand new BIG battery so I know it's not that, it turns over ok but just keeps turning. It usually eventually starts up but today if just gave up until, on pressing the startebutton, I got nothing. As soon as I put the jump leads on it fired up first time. What could this be? Dodgy starter?
HowardB - 23/2/16 at 03:30 PM
check the voltage drop on cranking, there was another thread on here not long ago asking similar questions,...
thread
and here too
hthmore
[Edited on 23/2/16 by HowardB]
benchmark51 - 23/2/16 at 04:45 PM
Check the earth leads are tight and not getting warm when cranking. Try a jump cable from battery earth to starter body. Poor earth between engine and chassis have caused this problem several times for me in the past.
AntonUK - 23/2/16 at 05:50 PM
I had a similar issue and after checking the above suggestions I pulled the starter open to find it full of crud. I cleaned it up and worked fine afterwards.
Sam_68 - 23/2/16 at 07:23 PM
Yep, this would be my first best guess, too.
paulc - 23/2/16 at 09:54 PM
I had a similar issue,
Turned out to be a build up of corrosion between the battery terminal and the cable clamp.
(look for a voltage between the terminal and the clamp when cranking)
Paul
garyo - 24/2/16 at 09:08 AM
Had a similar problem - turned out to be fuel pressure drop on cranking, and lack of non-return valve. Easy way to test is to manually earth the injectors for half a second to fill the manifold with mist then try again. If it fires, then voltage drop/fuelling is the issue.
Did it ever work?
lordbenny - 24/2/16 at 07:16 PM
I'm going to get it rolling roaded in the spring....it's on carbs by the way....would they be able to adjust the static cranking voltage when hooked up to the ecu?
Phil_1471 - 24/2/16 at 08:48 PM
Sounds like an earth issue, check resistance from Earth terminal to various points with an decent ohm meter, or get a jump cable and Earth from battery to engine block etc and see if that sorts it..
lordbenny - 24/2/16 at 09:13 PM
Going to try this at the weekend and get back to you all....thanks.
britishtrident - 24/2/16 at 09:54 PM
Not an unkown issue on Zetec transplants the problem is to do with EDIS giving too much advance at low speed for the Zetec due to a crank senor wiring issue.
The cause is likely be the Vrs+ and Vrs- wires on the crankshaft variable reluctor position sensor are reversed. This results in a phase shift in the sensor signal. The sensor should output a sine wave everytime a tooth passes the sensor but reversing the wires inverts it turning it into a cosine wave shifting the ignition timing by 10 degrees.
https://www.autosportlabs.net/images/5/54/EDIS_system_diagram.png
lordbenny - 24/2/16 at 10:53 PM
Are you suggesting that I should swap the wires over?
Phil_1471 - 4/3/16 at 04:17 PM
What was the verdict then?
lordbenny - 4/3/16 at 09:17 PM
That's a good question....I havnt cured the problem myself...it still is difficult start from cold. I am waiting for the weather to improve before I take it to Novatech for a tune up. http://www.novatech.info/contactus.html
AlanH - 4/3/16 at 10:39 PM
I've got a similar problem and posted it recently. Poor cold starting on a pinto. Starts OK when warm.
Checked earth and that's OK. Need to check voltage drop on battery next then I'll check for a lazy starter.
lordbenny - 5/3/16 at 11:19 AM
I tried connecting a jump lead from the negative Earth on the battery to the starter motor and I also removed the earth terminal where it meets the chassis and cleaned that up. I think my problem may lie in my start up procedure and the carbs. I have 45mm Dellortos so after turning on the fuel pum and waiting for everything t fill up I give it three pumps. I then turn over the engine not touching the throttle....I MIGHT start then but if you don't catch it, that's it's it! So, I'm now thinking it may be a carb issue. Will let you know once it's stopped showing!
