G'day LCB-ers;
Still plodding my way through wiring for the Nodiz Pro, for my silvertop Zetec. I reckon to have sorted most, if not all, of the necessary wiring
connections.
Except for the camshaft position sensor!! Where should this be connected? None of my Haynes manuals cover this item (mainly because
they're like me - too old
Apologies if its a daft question. Your advice on this will, as usual, be greatly appreciated.
[Edited on 14/3/16 by Dick Axtell]
I'm no expert on Nodiz, but i guess its similar to megajolt??? Are you using a toothed wheel or the flywheel? If so Nodiz will have all the
information it needs. I didnt need the camshaft sensor with megajolt.
I hope this helps.
On wasted spark ignition the cam sensor is really just provided for the injection system.
Stupid Question......Does it actually have cam shaft position sensor?....Unless you have VVT / VCT etc.
You will however need a Crankshaft position sensor...are you getting the two mixed up?.
You only need it for sequential fuel injection. So you won't need it for 99% of aftermarket ecu's carb or injection.
Nodiz does not need this signal, just leave the sensor there dormant.
As mentioned here - it needs a crankshaft signal, and if you want the benefits of a 3d advance table, then a TPS or MAP sensor.
[Edited on 14/3/16 by fossett]
What an interesting range of replies!! Thanks for all your advice.
Conclusion :-
Running Nodiz doesn't require a camshaft sensor connection.
what if like me you are about to start wireing nodiz to your st170 with vvt and pro controller ???????????
