Escort hazard switch
Norfolkluegojnr - 29/3/16 at 08:25 PM
having hazard issues.....
Indicators working fine, but when hazard switch is thrown the relay buzzes a bit then nothing.
I suspect the switch which I believe is a mk2 escort one - where the hell can I get one?
It has 6 pins on the back looks like this
link
Help gratefully received for MOT purposes!
19sac65 - 29/3/16 at 08:34 PM
Ebay 351684944705
cliftyhanger - 30/3/16 at 09:49 AM
Have you tried cleaning it? A soak in something to get rid of any grease (hot water and soap powder is pretty effective, you may be able to squirt in a solvent?) and then soak in vinegar or switch cleaner?
It is usually just bad contacts where they are used so rarely.
Norfolkluegojnr - 30/3/16 at 09:53 AM
I haven't. Its probably worth a try, it certainly hasnt had much use in the last few years!
Never heard of using vinegar, got to be worth a try....
