After some 205/60/13 for road use. Now only available new for track use as not E rated.
Cheers.
Why do you particularly want A048?
Are you using them for insulation? After all this is the electrics section of the forum , perhaps the wanted section would be better?
048s on the front. Also seem to be better in wet con5.
