Hi All
Just giving the Suttol it's spring clean and check over and noticed the wipers weren't working,
not that I use them, more just for decoration really. (Bit like fog lights on a tin top. )
Anyway, the reason was the fuse had blown. I basically used a low value (possibly) of 15amp when I
fitted and wired them thinking it was safer to go too low than too high. I've changed it for a 20amp.
So the question is, what should it have. I believe the original Mini had fuses that ran multiple items.
Paul G
Think they used 30 fuses but as you say there were several items covered by each fuse. If I get a chance I will have a look to see what fuses I have on mine tomorrow
Cheers Mel
Early ones had a fuse box with two 35 amp glass fuses, one for all ignition loads one for B+ loads
1977 onwards had multiple 25 amp glass fuses
Mine were running for ages with no problem on a 15a fuse but blew when the motor got tired. They seem fine again on 15a with a new motor.
Stu
the old glass fuses were about 17A/20A continuous, 35A blow. modern fuses are just rated as continuous
however the LucasFaultDiagnosisServiceManual suggests 2-4A, with a wet screen
Stu
I use a 20a fuse with my mini wiper, as im sure that's what the Haynes manual said for the BL mini
steve
steve
Just checked mine Paul ,it has a 15 amp fuse but I only have very short blades which probably cuts down the drag
If is was my wiper setup I'd take the blades off and try the mechanism, to see if it's running free and easy. There are 2 gearboxes under
the wipers, plus the flexible tube that drives them, and they may be short of lubrication.
If everything is running smoothly with no sign of struggling them maybe it is as easy as a dry screen. I'll have to see what fuse I'm
using, out of interest...
Originally posted by David Jenkins
If is was my wiper setup I'd take the blades off and try the mechanism, to see if it's running free and easy. There are 2 gearboxes under the wipers, plus the flexible tube that drives them, and they may be short of lubrication.
If everything is running smoothly with no sign of struggling them maybe it is as easy as a dry screen. I'll have to see what fuse I'm using, out of interest...
quote:if using second hand lucas style wipers, its worth rotating the inner drive spiral, and the gear/pinion by 180degrees to use the unworn gear teeth/drive
. Originally I bought two sets of wipers and striped them and used
the best parts.
A bit late to the party, but I have my dash off at the moment, so I had a look at the fuse for my Mini wipers. I've been using a 10A normal fuse (i.e. quick-blow) for the past year, without problems.
