Managed to get this cheap on fleabay
[img]
Smiths Rev counter
[/img]
but struggled to find out how to wire it up for coil/dizzy. Sussed it eventually but the web/google wasn't massively helpful. so here's the
back
rev counter rear
A = connect to the -ve side of the coil (side that goes to distributor)
B = connect to the +ve side of the coil
C = ground
That works for me anyway
http://www.gomog.com/allmorgan/smithsclassic.html
[Edited on 14/6/16 by alfas]
Thanks alfas, yes I found that diagram, and lots of other similar ones, but it doesn't relate to whats on the back of the tacho, so I eventually
worked it out by trial and error
Correct wiring is
A - points side of coil.
B - switched live
C - ground
Coil + is switched live, so you'll be ok.
