Hi all
I mentioned in a previous post that my brake lights only come on if you press the pedal hard, this isn't something you can do whilst driving
unless you fancy being rear ended.
It would appear even after bleeding the brakes and changing the pressure switch it has made no difference, can some kind person recommend me a
electrical type they have used with the current two wires and show how they have rigged it up to work on the pedal.
Mick
Pretty sure I put a pic up on your other thread of mine, classic mini on when released brake pedal switch.
What kind of pedals do you have? OEM switches are on the brake pedal...
http://www.locostbuilders.co.uk/forum/2/viewthread.php?fid=5&tid=173156
